lldp port
Configures LLDP on a port or ports.
Syntax
Command Parameters
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
cdp
Enables Cisco discovery protocol on the selected port(s) to accept CDP packets only.
The default is disabled.
status <txAndrx>
Specifies LLDP frames to transmit and receive on the selected port(s).
The default is enabled.
Default
The default is none.
Command Mode
GigabitEthernet Interface Configuration
